Print at Sep 23, 2026, 12:35:02 PM
Posted by Puybaret at Jul 19, 2021, 1:07:17 PM
Re: Export to HTML5 plug-in
Hello Matthias,
Reducing the total file size is a good way to help it work, but it could also be due to the size or the complexity of a 3D model you're using, even if I'm quite astonished you experienced this bug also on a Windows computer.
As the 3D model of invisible furniture isn't exported, you could try to export again your home after hiding its largest models (the 3D model size of each piece of furniture can be displayed in furniture list by choosing Furniture > Display column > Model size menu item). Once it works, try to find the culprit by showing the invisible furniture one after the other.
