Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Texture turned out different from Texture applied to cabinet. » » » » Post: Re: Texture turned out different from Texture applied to cabinet. |
Print at Oct 16, 2026, 8:13:10 PM |
| Posted by AlexQ at Aug 9, 2021, 3:26:32 PM |
Re: Texture turned out different from Texture applied to cabinet. Hi Hansmex, Thank you. With your instructions, I'm able to follow. https://www.mediafire.com/file/absim0bc2l3l7yy/width_height.jpg/file But when I tried to change the dimension of the wood texture to 600 mm (width) x 800 mm (height) to fit the other cabinet size. But the model doesn't allows it. It defaults to a square dimension. This appears to affect the color/texture to some extent. Is there any way to overcome this issue? Thank you for your prompt response. Alex Quek |
Current timezone is GMT Oct 16, 2026, 8:13:10 PM |
