Print at Oct 4, 2026, 4:58:43 PM
Posted by hansmex at Aug 13, 2021, 10:31:32 AM
Re: How to create an inclining wall
Try Modify walls -> Sloping wall to make a wall that's 10 m high at one end, and 11 m high at the other end.
If the base of your wall should be 10 m long, and the top should be 11 m long, there's no standard solution. Use this workaround:
- draw a wall 11 m long
- split it in two parts
- use Modify walls -> Sloping wall to make one side sloping
- repeat if both sides need to be sloping
- now you have an upside-down version of the wall you need
- export your wall as OBJ (selection only)
- import your wall and rotate it 90 degress during import
