Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Trying to understand how to run a locally modified/built SH3D » » » » Post: Re: Trying to understand how to run a locally modified/built SH3D |
Print at Sep 24, 2026, 12:08:08 AM |
| Posted by Puybaret at Aug 23, 2021, 6:18:54 PM |
Re: Trying to understand how to run a locally modified/built SH3D The SweetHome3D-version.jar file generated by the default Ant target is a JAR Executable file that can be run with a command like: java -jar /path/to/SweetHome3D-version.jarIf you want to run it with the same options as SweetHome3D-Java3D-1_5_2, you should add the option -Dcom.eteks.sweethome3d.j3d.version=1.5.2 after java command, i.e. java -Dcom.eteks.sweethome3d.j3d.version=1.5.2 -jar /path/to/SweetHome3D-version.jar---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 12:08:08 AM |
