Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Guide: Pipes » » » » Post: Re: Guide: Pipes |
Print at Oct 6, 2026, 12:21:49 AM |
| Posted by otadmin at Sep 11, 2021, 7:29:10 AM |
Re: Guide: Pipes Thanks for the guide. I want to draw water/heating pipes and electrical wires normally hidden inside walls. It is quite possible to draw the objects inside walls and make them visible/invisible by "Modify 3D view - Wall transparency". They can also be put into floors of rooms but only if the elevation is set from the room below. I group the objects as you suggested and can then hide/show example only the heating pipes. |
Current timezone is GMT Oct 6, 2026, 12:21:49 AM |
