Print at Oct 13, 2026, 4:13:39 AM
Posted by Niod at Sep 12, 2021, 11:07:20 AM
Re: Polyline and walls contour. How to change angle?
Thanks for the tip... But more questions has arisen recently:
- Why a segment of a wall can be transformed into the form of an arc, but segment of a polyline cannot? How to make a freeformed line contour, like in an ordinary vector graphic editor? An architector may need to make a more complex line contour, not only straight segments and simple symmetric arcs..
That wonderful program needs a full vector lines creating module, as in Corel Designer, for example.. To make a model of building with walls of variable thickness and complex geometry, one needs a good vector contour line creating tool..
- When I select a segment of a wall, there is no ability to open the menu "change wall" by right-clicking on it, the context menu is the same as without wall selecting, and I have to open "change walls" point every time
It's annoying a little.
These are just my considerations and suggestions for improvements! ))
Thank you so much for your work!
The program is quite good, and vector lines creating tools would make it absolutely excellent!
