Print at Oct 12, 2026, 4:43:14 PM
Posted by hansmex at Sep 14, 2021, 3:33:47 PM
Re: Octagon
1 - Click the walls icon
2 - Click on any point in the 2D window
3 - Hit ENTER
4 - Enter 0,0 as X,Y coordinates (or any other starting point you want, use TAB in between)
5 - Hit ENTER and the wall will stretch horizontally to the right from the starting coordinate
6 - Overwrite the suggested wall length
7 - Hit TAB and enter 135 degrees as angle
8 - Overwrite wall thickness if necessary
9 - hit ENTER
10 - repeat steps 5-9 seven times, SH3D will suggest the same wall length, change angle to 135 degrees - you will note that using TAB is enough to go to wall angle, then ENTER is enough to complete each step)
11 - after 7th repetition octagon is ready, on ENTER the last wall segment will join the first segment
(PS - I tried it twice after reading my text, it should work as described)
