Print at Oct 4, 2026, 6:08:14 AM
Posted by ManuMan79 at Sep 22, 2021, 5:39:37 PM
Re: Mac OS X Version 6.6.5 (MacApp Store) doesn't start
On Macbook M1 Monterey(bêta 12.0 (21A5506j) :
Do'nt start :
From Terminal
Last login: Wed Sep 22 15:46:38 on ttys000
You have mail.
Emmanuel@MBP13-M1 ~ % /Applications/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D ; exit;
CoreSVG has logged an error. Set environment variabe "CORESVG_VERBOSE" to learn more.
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by javax.media.j3d.JoglPipeline (file:/Applications/Sweet%20Home%203D.app/Contents/app/j3dcore.jar) to method sun.awt.AppContext.getAppContext()
WARNING: Please consider reporting this to the maintainers of javax.media.j3d.JoglPipeline
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x0000000112321b44, pid=60551, tid=9475
# JRE version: OpenJDK Runtime Environment Zulu15.29+15-CA (15.0.2+7) (build 15.0.2+7)
# Java VM: OpenJDK 64-Bit Server VM Zulu15.29+15-CA (15.0.2+7, mixed mode, tiered, compressed oops, g1 gc, bsd-aarch64)
# Problematic frame:
# J 1245 c2 jdk.internal.jimage.ImageStringsReader.charsFromByteBufferLength(Ljava/nio/ByteBuffer;)I [email protected] (47 bytes) @ 0x0000000112321b44 [0x0000000112321ac0+0x0000000000000084]
# No core dump will be written. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /Users/Emmanuel/hs_err_pid60551.log
Compiled method (c1) 2256 218 3 java.nio.DirectByteBuffer::<init> (55 bytes)
total in heap [0x000000010add3a10,0x000000010add41a8] = 1944
relocation [0x000000010add3b68,0x000000010add3bd8] = 112
main code [0x000000010add3c00,0x000000010add3fc0] = 960
stub code [0x000000010add3fc0,0x000000010add4078] = 184
metadata [0x000000010add4078,0x000000010add40a0] = 40
scopes data [0x000000010add40a0,0x000000010add4120] = 128
scopes pcs [0x000000010add4120,0x000000010add4190] = 112
dependencies [0x000000010add4190,0x000000010add4198] = 8
nul chk table [0x000000010add4198,0x000000010add41a8] = 16
# If you would like to submit a bug report, please visit:
# http://www.azulsystems.com/support/
zsh: abort /Applications/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
Deleting expired sessions... 6 completed.
[Opération terminée]
