Print at Sep 23, 2026, 3:56:55 PM
Posted by dorin at Oct 3, 2021, 12:51:04 PM
Generate roof plugin
In the series of YAUP: GenerateRoof plugin v1.0 alpha
!!! WARNING !!!
  • Fail on more than 90% of cases
  • Not all texture are correct rendered
Q:"Why you published like this?"
A:"It's a path trout jungle. Someone else could make a highway from this"
How I think to use:
  • Select a room (manually made or trout Autodimensioning))
  • Tools -> Generate roof... bla.. bla..
  • Set roof faces angle -> OK (optionally check inner polygons)
  • On preview click OK
Result something like this:
Now you have to set textures and texture angle:
Finally (if You have lack):
Don't forget!!!
It's an alpha stage AND
I'm not a programmer!
PS This is the test file .
