Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Limiter le chemin des visiteurs (mode visite virtuelle) » » » » Post: Re: Limiter le chemin des visiteurs (mode visite virtuelle) |
Print at Sep 29, 2026, 8:33:19 AM |
| Posted by Puybaret at Dec 14, 2021, 6:51:14 AM |
Re: Limiter le chemin des visiteurs (mode visite virtuelle) Hi, Limiting the moves of the virtual visitor would be only possible by program. For example, you could create a large room covering all the house, and check in JavaScript that the camera doesn’t go outside of this room after its coordinates changed. If you want to try, Sweet Home 3D JS API is available here. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 8:33:19 AM |
