Print at Sep 29, 2026, 2:08:30 AM
Posted by unitedwewillwin at Dec 24, 2021, 3:45:09 PM
Re: Import .obj file to Blender
I was facing the same issue and found a great, efficient way to separate objects in Blender (only takes a few seconds!)
To do that, just select the imported object in Blender, go into Edit Mode (pressing the "tab" hotkey on your keyboard), then press "P" on your keyboard. A small tab opens and you can choose to separate the items either by Material or by Loose Parts.
Here is the Youtube tutorial I found that explains it: https://www.youtube.com/watch?v=P_C3xkVT044
The only downside is that in the Blender Outliner, the different parts don't take the name they had in Sweet Home 3D. For example "Table" is called "ProjectName.001", but this can be manually changed.
Hope this helped!
