Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate roof plugin » » » » Post: Re: Generate roof plugin |
Print at Sep 23, 2026, 5:07:17 PM |
| Posted by dorin at Dec 26, 2021, 6:48:24 PM |
Re: Generate roof plugin Hi, bdfd. 1. I'm glad You try it and surprisingly work!!! 2. You've right, it's a bug. "Why?" When I make this I consider to be only one building in home plane. The last picture I've post (with more buildings) I have to correct manually this bug. Select all on newly Roof-gen level (roof & room under roof), cut and paste on first Roof-gen level. Then You delete the empty level. 3. I know is full of bugs and the worst was discovered by Hans. It appear don't like the very regular shapes and fail. When I make it I've tested on relatively complex shapes considering, on regular shape to work implicitly. I'm wrong! Unfortunately, after ~6 month of work 10~12 h/day to this, I need a break. 4. This approach seems to be also a dead way. Probably I need to learn python to convert Polyskel library or bpypolyskel with which maybe I don't need to reinvent the wheel. Happy New Year to everybody! ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 23, 2026, 5:07:17 PM |
