Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Wirings plugin » » » » Post: Re: Wirings plugin |
Print at Sep 23, 2026, 1:09:23 PM |
| Posted by hansmex at Jan 6, 2022, 6:31:34 AM |
Re: Wirings plugin Daniele, Thank you for version 1 of this new plug-in. Unfortunately I cannot get it to work. What did I do: - I made sure I have Pan3D v1.7 installed - I made sure I have Wiring v1.0 installed - I open a new, empty instance of SH3D - ! draw a square of 4 walls and insert a room - I click the button of the Selection pointer - I click the button of the Wiring tool. - The background of the Wiring tool turns blue. If I click the button again, the blue background turns white again. That's it. Nothing else happens. The last button clicked (before clicking the Wiring Tool), determines which action is executed AFTER clicking the Wiring button. If that's clicking the Selection button then the program stays in Selection mode after clicking the Wiring button. When I click a wall to start drawing wiring, I move the wall. When I clcik a floor, I move the floor. When (before clicking the Wiring button) I click the Walls button, then after activating the Wiring plugin, I will draw a wall, not wiring. - Variations: I tried it on an existing design, I tried it on a new level with equal elevation called WIRING, I tried it with Baseplan Locked. Nothing happens. I have several other plug-ins installed. Maybe your (combination of) plug-ins doesn't like some of the other plug-ins? I read your HELP file several times. Any suggestions?? Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 23, 2026, 1:09:23 PM |
