Print at Sep 23, 2026, 7:39:25 PM
Posted by SystemOfAFrown at Jan 15, 2022, 7:47:21 PM
Can you modify an existing .SH3D model with the API?
Hello,
I was wondering if you can use either the Java or Javascript API's to modify an existing .sh3d file.model.
The best example I can give for this, is having the user enter their preferences for color and design tastes on a webpage; and then the API code would change the colors of the walls; within the floorplan for example.
It would be the same manufactured home each time, so it would be from the same template .sh3d file.
Thank you for your time.
