Print at Oct 5, 2026, 6:25:29 PM
Posted by hansmex at Jan 15, 2022, 9:16:05 PM
Re: A Service Hatch leaves a white stripe on the floor. Can this be avoided?
If you insert an inverted u-shaped object into a wall, the wall will fill up.
If you add a closing part at the bottom, that part will leave a gap in the floors you insert afterward.
The trick is to make an insert with a bottom closing part that is as thin as possible, making it almost invisible.
