Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Defective autosave » » » » Post: Re: Defective autosave |
Print at Oct 4, 2026, 9:32:47 PM |
| Posted by Puybaret at Jan 17, 2022, 9:33:05 PM |
Re: Defective autosave You might have encountered the same issue as in the bug #1075. First, be sure that the auto save is probably the best solution in a JavaScript environment where a crash with a page reload may occur at any moment when resources are missing. I see from the server logs that the exports you obtain from your 3 projects contain the last changes received by the server. But let's try to understand why the server didn't receive the last changes you made. I hope you kept the windows of your 3 projects opened (or at least one), so you can report what the content of the JavaScript console. Display it by choosing the menu item More tools > Developer tools (Ctrl+Shift+I) and select the Console tab. The Console should contain some lines stating Failed to load resource: the server responded with a status of 404 (Not Found)---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 4, 2026, 9:32:47 PM |
