Print at Oct 4, 2026, 10:40:19 PM
Posted by Daniels118 at Jan 25, 2022, 7:04:42 PM
Re: Pan tool in 3D and 2D view?
Hi Emmanuel,
thank you for the video, it helped me understand what was going on. I've releasead a new version of the plugin which should fix the bug. unfortunately I cannot test it by myself on a macOS, I hope it works. If you still experience problems you have 2 options:
  • help me debug the code;
  • turn off the exponential wheel using the new settings panel available under 3D view -> Pan 3D view settings menu.
I've also added an alternate way to pan for macOS, see below.
Summary of the changes:
  • Added ALT+left mouse button as an alternative to middle mouse button for panning (for macOS users)
  • Added the SHIFT key support to increase the speed of the scroll wheel in the 3D view
  • Improved exponential mouse wheel
  • Implemented a limit for the max distance when moving backward with the scroll wheel
  • Fixed the behavior in virtual visitor mode when custom mouse handlers wish to prevent camera rotation (1)
  • Added a preferences panel to:
    • enable/disable exponential mouse wheel
    • enable/disable select transparent walls with mouse
1) this change fixes the annoying bug occurring when moving points in virtual visitor mode for Wirings and 3D dimension lines plugins.
Download from here: Pan3dView-2.0.sh3p
