Print at Sep 27, 2026, 3:20:14 AM
Posted by alied at Mar 18, 2010, 4:27:04 PM
Re: Update on DirectX
read this on the FAQ page:
I got the message Sweet Home 3D will exit now because of a fatal error in 3D rendering system. What can I do?
# If this update still doesn't fix your problem, click on this link to run Sweet Home 3D with the DirectX version of the Java 3D library, or if you prefer to run Sweet Home 3D from its installer, download the file SweetHome3D.l4j.ini , copy it in Sweet Home 3D installation directory (by default it's C:\Program Files\Sweet Home 3D) and relaunch Sweet Home 3D.
there you can get a .ini file to specify the amount of memory you want for the program.
I too was working with huge textures, and had to give up to 1GB for it to work properly.
