Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How do I create an Arched Roof » » » » Post: Re: How do I create an Arched Roof |
Print at Oct 2, 2026, 2:04:25 PM |
| Posted by sjb007 at Feb 14, 2022, 12:25:15 AM |
Re: How do I create an Arched Roof Create walls in SH3D as if you were in front projection. i.e. in SH3D looking from above it would look like ⋀ or ⋂ or whatever before export, import and rotation. Make them as tall as your model is deep, and arc them so they match the desired front projection. Select them, then export them as an object, then import them as a new furniture item, rotating the object so that the arch is in the correct orientation. One word of warning, if you want textures, or windows and doorways in the model you will have to do it before export. When you import it back in it loses its ability to act like a wall. This makes it a bit inflexible, but it works in a pinch. |
Current timezone is GMT Oct 2, 2026, 2:04:25 PM |
