Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Floor have huge size in svg (tens of Mb) » » » » Post: Re: Floor have huge size in svg (tens of Mb) |
Print at Sep 28, 2026, 9:56:50 PM |
| Posted by Daniels118 at Feb 14, 2022, 6:57:43 AM |
Re: Floor have huge size in svg (tens of Mb) Not sure why, Daniel, but it seems I'm your nemesis AHAHAH ![]() Please check the cpu usage using the task manager while exporting to svg. I suspect that compressing that image could be too heavy for the compression algorithm. I was expecting there might be problems, so I figured out a way to change the default settings without rebuilding the plugin. You could try to decrease the compression level by starting sh3d with a java property named png.compression,it accepts integer values in range 0-9 (the default is 9). |
Current timezone is GMT Sep 28, 2026, 9:56:50 PM |
