Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Floor have huge size in svg (tens of Mb) » » » » Post: Re: Floor have huge size in svg (tens of Mb) |
Print at Sep 29, 2026, 9:58:50 PM |
| Posted by sjb007 at Feb 14, 2022, 12:07:45 PM |
Re: Floor have huge size in svg (tens of Mb) I'm not even convinced the compression is working. I tried with compression set at 0 and 1 so far and they both produced 6,052 KB files and both took approximately 48 min. I'm assuming the command I posted is what you intended. I'm just in the middle of running a level 5 test to see if that produces the same result. Once that completes I'll see if stripping the file back to just the background image still causes the long delay, and post it up for you as a stripped back example. |
Current timezone is GMT Sep 29, 2026, 9:58:50 PM |
