Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: 3D rendering issues » » » » Post: Re: 3D rendering issues |
Print at Sep 27, 2026, 4:24:03 PM |
| Posted by Puybaret at Feb 14, 2022, 2:22:15 PM |
Re: 3D rendering issues This is generally due to imported DAE files which defined their shape with double faces (interior and exterior faces). The easiest way to fix it is to make these faces invisible in the Furniture Materials dialog box. These materials shouldn't be visible in the preview of this dialog box when you select them and their name is generally very simple. The small white spots on the windows are just some noise. Reducing the size of the rendered image will make them less visible. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 27, 2026, 4:24:03 PM |
