Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate roof plugin » » » » Post: Re: Generate roof plugin |
Print at Sep 24, 2026, 11:13:21 PM |
| Posted by dorin at Feb 18, 2022, 8:47:36 AM |
Re: Generate roof plugin Hi Daniele! Let's start with good news: WORK!!! After few modifications (work only with rooms in clock wise) and I fix it. Work with ALL my files used for test including some improbably shape. Now some TODO: -this version is the stable one which don't allow negative value for weight (like we see in the demo video). I have both and I'll try to update current files You have share. -somewhere in org.twak.utils is a import_obj.py file used to import obj+mtl files in Blender. That's mean somewhere this files are generated. I'll see where. If so is all I need to pass them to exportObject(). It's too good to be true! -for 3D I've see this in src. All this mean I've have to start work from 0 the roof plugin and it's OK. Thanks again for priceless help!! Dorin ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 24, 2026, 11:13:21 PM |
