Print at Oct 6, 2026, 7:51:43 AM
Posted by renaudpawlak at Feb 21, 2022, 2:20:40 PM
Re: SweetHome3DJS won't compile
Well, that's annoying... Apparently, tsc does not install where JSweet expects it to be installed.
Maybe the installation went wrong for some reason, to you might try to remove the .jsweet.v3-node_modules directory and try again.
Otherwise, as a dirty quickfix, you may try to manually copy .jsweet.v3-node_modules/node_modules/.bin/tsc.cmd to .jsweet.v3-node_modules/tsc and see what happens.
