Print at Oct 6, 2026, 9:38:01 PM
Posted by bernard_s at Feb 22, 2022, 5:29:27 PM
Re: SweetHome3DJS won't compile
Hi both,
The good news is that installing node version 14.7.6 allowed the build to complete successfully :) I was on node v16.14.0. I have now deployed the war and can see/use the editor. The bad news is that I am unable to save anything. I draw something, wait a while and get a browser console error 500 for writeHomeEdits.jsp and then "update failed" which reports sweethome3d.min.js line
87200. This line is within function IncrementalHomeRecorder.prototype.sendUndoableEdits:
request.send("home=" + encodeURIComponent(d.name) + "&editionId=" + d.editionId + "&updateId=" + f.id + "&version=" + this.application.getVersion() + "&edits=" +
encodeURIComponent(JSON.stringify(f.edits)))
In the java log (see whole chunk below), I also see:
22-Feb-2022 17:16:14.610 SEVERE [http-nio-8080-exec-5] org.apache.catalina.core.StandardWrapperValve.invoke Servlet.service() for servlet [jsp] in context with path [/SweetHome3DJS-6.6.4] threw exception
java.io.IOException: An exception occurred processing [/writeHomeEdits.jsp] at line [47]
44: // Get preferences stored as an application attribute
45: UserPreferences serverUserPreferences = (UserPreferences)getServletContext().getAttribute("serverUserPreferences");
46: if (serverUserPreferences == null) {
47: serverUserPreferences = new ServerUserPreferences(
48: new URL [] {new URL(serverBaseUrl, "lib/resources/DefaultFurnitureCatalog.json")}, serverBaseUrl,
49: new URL [] {new URL(serverBaseUrl, "lib/resources/DefaultTexturesCatalog.json")}, serverBaseUrl);
50: getServletContext().setAttribute("serverUserPreferences", serverUserPreferences);
Caused by: java.net.ConnectException: Connection timed out (Connection timed out)
Any ideas?
Bernard
Stacktrace:
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:494)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:379)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:764)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:227)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:162)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:189)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:197)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:540)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:135)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:687)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:359)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:399)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:889)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1735)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:829)
at java.base/java.net.PlainSocketImpl.socketConnect(Native Method)
at java.base/java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:399)
at java.base/java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:242)
at java.base/java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:224)
at java.base/java.net.Socket.connect(Socket.java:609)
at java.base/java.net.Socket.connect(Socket.java:558)
at java.base/sun.net.NetworkClient.doConnect(NetworkClient.java:182)
at java.base/sun.net.www.http.HttpClient.openServer(HttpClient.java:474)
at java.base/sun.net.www.http.HttpClient.openServer(HttpClient.java:569)
at java.base/sun.net.www.http.HttpClient.<init>(HttpClient.java:242)
at java.base/sun.net.www.http.HttpClient.New(HttpClient.java:341)
at java.base/sun.net.www.http.HttpClient.New(HttpClient.java:362)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1253)
at java.base/sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1187)
at java.base/sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1081)
at java.base/sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:1015)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1592)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1520)
at java.base/java.net.URL.openStream(URL.java:1165)
at com.eteks.sweethome3d.io.ServerUserPreferences$JSONResourceBundle.<init>(Unknown Source)
at com.eteks.sweethome3d.io.ServerUserPreferences$1.<init>(Unknown Source)
at com.eteks.sweethome3d.io.ServerUserPreferences.<init>(Unknown Source)
at org.apache.jsp.writeHomeEdits_jsp._jspService(writeHomeEdits_jsp.java:158)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:466)
... 25 more
