Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Default fill when creating a room » » » » Post: Re: Default fill when creating a room |
Print at Oct 2, 2026, 9:04:33 PM |
| Posted by sjb007 at Mar 8, 2022, 5:45:58 PM |
Re: Default fill when creating a room In the installed version use the "Display floor" checkbox in the "Modify room..." dialog box to make the floor invisible. The room still appears in the plan. You can seperately display a ceiling, and double-clicking the room will create walls. You just won't have anything in the 3D view. If you want the room to be transparent in the plan you can create a transparent png, then import it as a texture and assign to the floor. This will apppear unfilled in the plan, but solid in the 3D view. If you try using "Display floor" to hide the floor, then the room outline will revert back to grey. I don't know if any of this exactly achieves what you want, but maybe it helps. |
Current timezone is GMT Oct 2, 2026, 9:04:33 PM |
