Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Plugins manager » » » » Post: Re: Plugins manager |
Print at Sep 29, 2026, 9:26:06 AM |
| Posted by YGYL at Mar 18, 2022, 12:57:47 PM |
Re: Plugins manager I think a lot of people who use SH3D are some real newbies and are not likely to use the furniture library editor. (And the furniture library editor doesn't have this feature.) And will not go to use the picture editing software. (That is, using it is also a very troublesome thing) The core of this thing is that an object is used multiple times and only occupies 1 file size. For example, as I said before, it is best to let the object library directly support the KMZ format (now the furniture library editor is all OBJ to save, as long as the same parts of the object KMZ is much smaller than OBJ, such as a large tree 3D model) And I'm talking about the advanced version of this kind of thing, not only the same object inside the same part to save space, and the object can be called by another combination of objects, as long as you can save a lot of time and file space I have been in contact with SH3D for more than 10 years, I think this is the most critical feature Because in my opinion the value of SH3D is a simple 3D model placement tool, and then a tool for drawing walls. It's not 10 years ago ~ the online platform of big companies is free and easy to use, the layout can be automated, the rendering effect is fast and good. If SH3D doesn't change, less and less people will use SH3D. 10 years I feel it very obvious~. |
Current timezone is GMT Sep 29, 2026, 9:26:06 AM |
