Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Installing Sweet Home 3D JS Online on my server » » » » Post: Re: Sweet Home 3D JS Online |
Print at Oct 5, 2026, 4:34:44 PM |
| Posted by kingoftailor at Mar 25, 2022, 11:51:01 AM |
Re: Sweet Home 3D JS Online I think I did that, but the result is a zip file: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS>ant -buildfile build.xml Buildfile: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\build.xml viewerLibraries: transpiledLibraries: [mkdir] Created dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\SweetHome3DJSweetExtension [javac] D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\build.xml:32: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds [javac] Compiling 4 source files to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\SweetHome3DJSweetExtension [javac] warning: [options] bootstrap class path not set in conjunction with -source 8 [javac] 1 warning [mkdir] Created dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\ts [mkdir] Created dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\js [java] INFO: JSweet transpiler version 3.2.0-SNAPSHOT (build date: 2021-07-28 14:35:21) [java] 2022-03-25 12:38:58.058 INFO JSweetCommandLineLauncher:682 - input dirs: [..\SweetHome3D\src, tools\JSweet\src] [java] 2022-03-25 12:38:58.058 INFO JSweetCommandLineLauncher:694 - classpath: null [java] 2022-03-25 12:38:58.058 INFO JSweetCommandLineLauncher:709 - included: [def.*, com/eteks/sweethome3d/model.*, com/eteks/sweethome3d/tools.*, com/eteks/sweethome3d/viewcontroller.*, com/eteks/sweethome3d/io.*] [java] 2022-03-25 12:38:58.058 INFO JSweetCommandLineLauncher:710 - excluded: [] [java] 2022-03-25 12:38:58.058 INFO JSweetCommandLineLauncher:715 - add sources from directory: ..\SweetHome3D\src [java] 2022-03-25 12:39:00.000 INFO JSweetCommandLineLauncher:715 - add sources from directory: tools\JSweet\src [java] 2022-03-25 12:39:00.000 INFO JSweetCommandLineLauncher:760 - ts output dir: tools\JSweet\build\ts [java] 2022-03-25 12:39:00.000 INFO JSweetCommandLineLauncher:767 - js output dir: tools\JSweet\build\js [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:423 - no configuration file found at D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\.\jsweetconfig.json [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:528 - creating transpiler version 3.2.0-SNAPSHOT (build date: 2021-07-28 14:35:21) [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:530 - current dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\. [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:531 - base directory: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\. [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:532 - working directory: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:533 - tsOut: tools\JSweet\build\ts - D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\ts [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:534 - jsOut: tools\JSweet\build\ts - D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\ts [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:535 - candyJsOut: tools\JSweet\build\js [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:536 - factory: com.eteks.sweethome3d.jsweet.SweetHome3DJSweetFactory@525b461a [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:123 - candies processor classpath: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\.\jsweet_extension;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\bigjs-3.1.0-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-awtgeom-1.8.132-20200519.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-batik-svgpathparser-1.10.0-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-swingundo-1.8.132-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-core-6.3.1.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\SweetHome3DJSweetExtension;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3D\libtest\jnlp.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3D\libtest\AppleJavaExtensions.jar [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:141 - extracted candies directory: tools\JSweet\build\js [java] 2022-03-25 12:39:00.000 INFO JSweetCommandLineLauncher:891 - definition input dirs: [] [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:561 - node version: v14.17.1 [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:226 - 6 candies found in classpath [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:168 - candies changed, processing candies: CandyStore=[(commons-lang3-3.9,t=1627482944000), (bigjs-3.1.0-20170726,t=1501064550000), (j4ts-awtgeom-1.8.132-20200519,t=1589870766000), (j4ts-batik-svgpathparser-1.10.0-20170726,t=1501061682000), (j4ts-swingundo-1.8.132-20170726,t=1501060798000), (jsweet-core-6.3.1,t=1609936488000)] [java] WARNING: An illegal reflective access operation has occurred [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:295 - extract candy: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies.jar javaOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\src\jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies tsDefOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\typings jsOutputDir=tools\JSweet\build\js\jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies [java] WARNING: Illegal reflective access by org.jsweet.transpiler.util.Util (file:/D:/SWEETHOME3D/sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4/SweetHome3DJS/tools/JSweet/lib/jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies.jar) to field com.sun.tools.javac.tree.JCTree.type [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:295 - extract candy: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\bigjs-3.1.0-20170726.jar javaOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\src\bigjs-3.1.0-20170726 tsDefOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\typings jsOutputDir=tools\JSweet\build\js\bigjs-3.1.0-20170726 [java] WARNING: Please consider reporting this to the maintainers of org.jsweet.transpiler.util.Util [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:295 - extract candy: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-awtgeom-1.8.132-20200519.jar javaOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\src\j4ts-awtgeom-1.8.132-20200519 tsDefOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\typings jsOutputDir=tools\JSweet\build\js\j4ts-awtgeom-1.8.132-20200519 [java] WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:295 - extract candy: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-batik-svgpathparser-1.10.0-20170726.jar javaOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\src\j4ts-batik-svgpathparser-1.10.0-20170726 tsDefOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\typings jsOutputDir=tools\JSweet\build\js\j4ts-batik-svgpathparser-1.10.0-20170726 [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:295 - extract candy: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-swingundo-1.8.132-20170726.jar javaOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\src\j4ts-swingundo-1.8.132-20170726 tsDefOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\typings jsOutputDir=tools\JSweet\build\js\j4ts-swingundo-1.8.132-20170726 [java] WARNING: All illegal access operations will be denied in a future release [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:295 - extract candy: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-core-6.3.1.jar javaOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\src\jsweet-core-6.3.1 tsDefOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\typings jsOutputDir=tools\JSweet\build\js\jsweet-core-6.3.1 [java] 2022-03-25 12:39:01.001 INFO JavaCompilationComponents:122 - creating JavaCompiler task with options: JavaCompilerOptions: [--module-path, D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\.\jsweet_extension;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\bigjs-3.1.0-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-awtgeom-1.8.132-20200519.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-batik-svgpathparser-1.10.0-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-swingundo-1.8.132-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-core-6.3.1.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\SweetHome3DJSweetExtension;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3D\libtest\jnlp.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3D\libtest\AppleJavaExtensions.jar, -cp, D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\.\jsweet_extension;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\bigjs-3.1.0-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-awtgeom-1.8.132-20200519.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-batik-svgpathparser-1.10.0-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-swingundo-1.8.132-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-core-6.3.1.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\SweetHome3DJSweetExtension;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3D\libtest\jnlp.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3D\libtest\AppleJavaExtensions.jar, -Xlint:path, -encoding, ISO-8859-1] [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\AutoRecoveryManager.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\Base64.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\ContentDigestManager.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\ContentRecording.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\DamagedHomeIOException.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\DefaultHomeInputStream.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\DefaultHomeOutputStream.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\DefaultLibrary.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\DefaultPatternTexture.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\HomeContentContext.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\HomeFileRecorder.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\HomeXMLHandler.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\ObjectXMLExporter.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\ResourceBundleTools.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\XMLWriter.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\AspectRatio.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\BackgroundImage.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Baseboard.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\CatalogItem.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\CatalogPieceOfFurniture.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\CatalogTexture.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\CollectionChangeSupport.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\CollectionEvent.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\CollectionListener.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Content.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\DoorOrWindow.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Elevatable.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\FurnitureCatalog.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\FurnitureCategory.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeApplication.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeDescriptor.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeMaterial.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeObject.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomePrint.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeRecorder.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeTexture.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\IllegalHomonymException.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\LengthUnit.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Library.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Light.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\LightSource.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\PatternsCatalog.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\PieceOfFurniture.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\RecorderException.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Sash.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Selectable.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\SelectionEvent.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\SelectionListener.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\TextStyle.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\TextureImage.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\TexturesCatalog.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\TexturesCategory.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Transformation.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\tools\ExtensionsClassLoader.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\tools\OperatingSystem.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\tools\URLContent.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\AbstractPhotoController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\BaseboardChoiceController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ContentManager.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\Controller.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\DialogView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ExportableView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\FurnitureCatalogController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\FurnitureView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\HelpController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\HelpView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\HomeController3D.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\HomeView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ImportedFurnitureWizardStepsView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\LocalizedUndoableEdit.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ModelMaterialsController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\Object3DFactory.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ObserverCameraController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\PlanView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\PrintPreviewController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\TextureChoiceController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\TextureChoiceView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ThreadedTaskController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ThreadedTaskView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\TransferableView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\UserPreferencesController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\VideoController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\View.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ViewFactory.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ViewFactoryAdapter.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\WizardController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\HomeXMLExporter.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\CatalogDoorOrWindow.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\CatalogLight.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\DefaultFurnitureCatalog.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Camera.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Compass.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\DimensionLine.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeEnvironment.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Label.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Level.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Polyline.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Room.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Wall.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomePieceOfFurniture.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\DamagedHomeRecorderException.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\InterruptedRecorderException.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\NotEnoughSpaceRecorderException.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\UserPreferences.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\DefaultTexturesCatalog.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\HomeURLContent.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\tools\ResourceURLContent.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\tools\SimpleURLContent.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\tools\TemporaryURLContent.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\PhotoController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\PhotosController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\CompassController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\FurnitureController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\Home3DAttributesController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\HomeFurnitureController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\LabelController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\LevelController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\PageSetupController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\PolylineController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\RoomController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\WallController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\BackgroundImageWizardController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ImportedFurnitureWizardController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ImportedTextureWizardController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\ObserverCamera.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Home.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeDoorOrWindow.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeFurnitureGroup.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeLight.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\DefaultUserPreferences.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\FileUserPreferences.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\HomeController.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\PlanController.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1170 - creating bundle file: tools\JSweet\build\ts\bundle.ts [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1227 - created tools\JSweet\build\ts\bundle.ts [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning tools\JSweet\src\def\sweethome3d\Core.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning tools\JSweet\src\def\sweethome3d\SAXParser.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning tools\JSweet\src\def\sweethome3d\Scene3D.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning tools\JSweet\src\def\sweethome3d\SweetHome3D.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1170 - creating bundle file: tools\JSweet\build\ts\bundle.d.ts [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1227 - created tools\JSweet\build\ts\bundle.d.ts [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:865 - ts2js on org.jsweet.transpiler.TypeScript2JavaScriptWithTscTranspiler@7e3a2542 sourceFiles=137 [java] 2022-03-25 12:39:12.012 INFO TypeScript2JavaScriptWithTscTranspiler:84 - launching tsc... [java] 2022-03-25 12:39:18.018 INFO JSweetTranspiler:1330 - js output file: tools\JSweet\build\js\bundle.js [java] 2022-03-25 12:39:18.018 INFO JSweetTranspiler:849 - transpilation process finished in 17693 ms [java] > java2ts: 11453.4937ms [java] > ts2js: 5906.115ms [java] [java] INFO: transpilation successfully completed with no errors and no warnings [move] Moving 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\lib\generated [move] Moving 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\lib\generated [move] Moving 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\lib\generated [delete] Deleting directory D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build viewerConcat: [delete] Deleting directory D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist [mkdir] Created dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist\build commonLibrariesDistribution: install-yuicompressor: [copy] Copying 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist [copy] Copying 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist [copy] Copying 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist [copy] Copying 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist [copy] Copying 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist [copy] Copying 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist [copy] Copying 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist viewerDistribution: [delete] Deleting directory D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist\build [echo] Javascript viewer files in dist ready for ftp viewerBuild: [mkdir] Created dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\install\viewer\SweetHome3DJSViewer-6.6.4\lib [copy] Copying 13 files to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\install\viewer\SweetHome3DJSViewer-6.6.4\lib [copy] Copying 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\install\viewer\SweetHome3DJSViewer-6.6.4 [zip] Building zip: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\install\SweetHome3DJSViewer-6.6.4.zip [delete] Deleting directory D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\install\viewer\SweetHome3DJSViewer-6.6.4 [echo] install/SweetHome3DJSViewer-6.6.4.zip ready BUILD SUCCESSFUL |
Current timezone is GMT Oct 5, 2026, 4:34:44 PM |
