Print at Sep 30, 2026, 5:48:32 PM
Posted by Puybaret at Apr 6, 2022, 11:18:35 AM
Re: Importing Blender model with textures into SH3D
Sweet Home 3D doesn't support map_Bump, map_Ke and map_d parameters in MTL format. It supports only textures defined with map_Kd parameter and as you noticed, you should try to save them in the same folder as the MTL file to avoid possible issues.
