Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Sweet Home 3D Online Manager » » » » Post: Re: Sweet Home 3D Online Manager |
Print at Oct 4, 2026, 11:25:49 PM |
| Posted by Puybaret at Apr 7, 2022, 11:20:01 AM |
Re: Sweet Home 3D Online Manager However, there must be a connected user for everything to work No, the default web application proposed with Sweet Home 3D JS is able to record the changes made in a file matching the home parameter sent to index.jsp (see also readHome.jsp). For example:will edit the file MyHome.sh3d, creating it if it doesn't exist. But if you don't want to keep all the SH3D files in the same folder and/or prevent the SH3D files of a user from being read by anyone, you'll have to program some authentication system, the reason why I reused the forum login page as a SSO (Single Sign-On) on sweethome3d.com. But you could also start without authentication and use a permanent cookie to name the folder matching a user on the server. is the Online Manager also available for download? No, because it depends on the forum authentication system and how sweethome3d.com database is organized. I could program also a less specific solution but I prefer to spend some time on Sweet Home 3D improvements now.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 4, 2026, 11:25:49 PM |
