Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Is there a method to crop an object diagonally? » » » » Post: Re: Is there a method to crop an object diagonally? |
Print at Sep 30, 2026, 8:13:01 PM |
| Posted by Keet at Apr 8, 2022, 11:58:31 AM |
Re: Is there a method to crop an object diagonally? You can get a 45° angle for your surface boards by setting the angle to 45° when importing the texture. Besides grouping you can use the object export and import features to get a permanent group of objects into a single object: Select all the objects that need to be combined. Export these: 3D View, Export to OBJ format (export selected, not all) Import the exported object (Furniture, Import furniture) and you have your single furniture object. Remember that you can no longer edit the individual parts unless you keep a copy of the group of original objects somewhere saved to repeat the process when required. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 30, 2026, 8:13:01 PM |
