Print at Oct 7, 2026, 11:40:06 PM
Posted by Puybaret at Apr 14, 2022, 1:36:58 PM
Re: Door - Arc Angle Line
Hi Chudst,
I replaced the doorOrWindow... properties of an existing door by your properties and it worked correctly. I would suspect that you have Pokojove_dvere model in more than a SH3F file loaded by Sweet Home 3D, or maybe that you edited the properties of a SH3F file stored in private folders of Sweet Home 3D which is not a good idea.
Last idea: the number of the properties ...#... in PluginFurnitureCatalog.properties file must follow each other, i.e. if it doesn't contain the name#5 the model defined by name#6 won't be taken into account.
