Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Wirings plugin » » » » Post: Re: Wirings plugin |
Print at Sep 23, 2026, 10:37:06 AM |
| Posted by mirakels at Apr 14, 2022, 7:03:13 PM |
Re: Wirings plugin I played a bit with version 3 of the plugin. I works reasonably good! A few remarks - when I change the thickness of the polyline it does show the change in plan view, but not in 3D view. - when I use the 'edit points' and delete or add a point from a wire (by accident or deliberate), I cannot add/change any wires in 3D-view anymore. I guess that this last one is because 'edit points' degrades a wire to a normal polyline... It would be great if Puybaret could work with you to integrate this plugins functionality into the main program (and hence support a height/elevation parameter for polyline points)! That would also solve my issue as described in the wishlist forum ;) Thanks for the good work Daniels118 |
Current timezone is GMT Sep 23, 2026, 10:37:06 AM |
