Print at Sep 23, 2026, 10:37:36 AM
Posted by Daniels118 at Apr 15, 2022, 10:01:29 AM
Re: Wirings plugin
Hi mirakels, thank you for your feedback.
- you're right, the thickness in the 3D view doesn't update, it will be fixed in the next release.
- the Wirings plugin has its own function to remove and add points directly from the 3D view (see the user guide available from the help menu). Version 3.0 has a bug that occurs when you try to add a point, but this has been already fixed in version 4.0 alpha.
In the next release I'll try to make the wirings compatible with the Advanced editing plugin. Of course you still won't be able to edit the elevation, but at least wirings won't break anymore.
Although I could integrate the polyline elevation within a plugin, I think this is a feature that should be handled by the main program, or at least by the Advanced editing plugin.
What I could do is to add an offset parameter so that wirings can be pushed within floors, walls, and ceilings. This feature would be available only for automatic wirings, since this would break the manual editing. You can try automatic wiring by installing version 4.0 alpha, I would be happy to receive your feedback on this new feature.
