Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Delete background image » » » » Post: Re: Delete background image |
Print at Oct 3, 2026, 4:54:01 PM |
| Posted by Puybaret at Apr 17, 2022, 12:13:01 PM |
Re: Delete background image A level uses the same background image as the previous level if they are at the same elevation. If you change its order with the arrows at the right of the levels table shown in the Level modification dialog, it won't display it anymore. You could also change its elevation adding a very small value like 0.001 cm. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 3, 2026, 4:54:01 PM |
