Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: How to create opening doors » » » » Post: Re: How to create opening doors |
Print at Sep 29, 2026, 6:21:38 PM |
| Posted by Daniels118 at May 12, 2022, 5:29:22 PM |
Re: How to create opening doors I never tried it, but looking at a working door, I think you should add a common identifier after the prefix, and then add a different suffix for each node. For example you should: - name the pivot "sweethome3d_hinge_1", - name the door as "sweethome3d_opening_on_hinge_1_door", - the handle as "sweethome3d_opening_on_hinge_1_handle", - the glass as "sweethome3d_opening_on_hinge_1_glass", - and so on... Also, looking at the code, I think the identifiers must be integers, in sequence, and starting from 1, otherwise it could not work. |
Current timezone is GMT Sep 29, 2026, 6:21:38 PM |
