Print at Oct 3, 2026, 11:27:27 PM
Posted by Keet at May 17, 2022, 8:21:14 AM
Re: Looking for a 3D model of a purse
Search archive3d.net with duckduckgo or google using "bag site:archive3d.net" (repeat searches with purse, handbag, 'hand bag' etc.) You will find several bags where one of them might come close to what you are searching for.
Don't expect to find all bags/purses in a 'logical' category. I found a bag using the mentioned method in the 'Home Appliances' category smile
If you encounter problems: sometimes the 3ds file gives better results than the obj file. Textures will sometimes not apply correctly, especially when they are in a subdirectory. Unzip and copy all textures to the same directory as the model file. You can also import textures using SweetHome3D after importing the model.
Or create it yourself:
If the purse you are looking for is really cylindrical you can use the cylinder object. Resize it and rotate to fit what you need. Apply a texture and add the handle. Zooming in to the max gives you the chance to place objects to the millimeter using the arrow keys.
If the purse needs rounded sides you can add spheres to the ends, partly sunk in the cylinder.
