Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Aligning objects on a curve » » » » Post: Re: Aligning objects on a curve |
Print at Sep 30, 2026, 7:51:45 AM |
| Posted by Puybaret at May 19, 2022, 8:54:25 AM |
Re: Aligning objects on a curve Hi, You could try to draw the curved path with round walls (read FAQ How can I create round walls? if needed) then place the chairs along this wall. Even if magnetism doesn't work perfectly with round walls, it will help you to place them at the tangent of round walls. It seems to work better to add the chair first then place it along a wall. See attached example. ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 30, 2026, 7:51:45 AM |
