Print at Aug 26, 2026, 4:21:22 PM
Posted by sruuk at May 19, 2022, 11:13:14 AM
Re: copy level and seperate
thanks for your response, it is walls that I want to change between the variants. I am very reluctant to save as a separate file as then I cannot track the changes on the other levels, I already have 7 different files and each time I make a change which applies to all I need to make the same change in 7 files.. it would would be amazing if I could have it all in 1 file.
If its not possible at the moment how likely is it that "untracked" levels might be added as a feature?
Many thanks
