Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: copy level and seperate » » » » Post: Re: copy level and seperate |
Print at Aug 26, 2026, 4:21:24 PM |
| Posted by sruuk at May 19, 2022, 8:46:38 PM |
Re: copy level and seperate Just tried it and you can build walls on each level at the same elevation separately. Just make the other levels invisible. The changes you make on the visible layer will not influence the invisible ones. I will try that, many thanks to you all. |
Current timezone is GMT Aug 26, 2026, 4:21:24 PM |
