Print at Sep 23, 2026, 11:52:32 AM
Posted by Puybaret at May 23, 2022, 2:25:53 PM
Re: Terrain Generator plug-in
Here's the version 1.2 of the Terrain Generator plug-in which provides the following improvements:
- Magnetism was renamed as Multiple points and Alignment as Row modification
- Multiple points and Row modification states can also be toggled with check boxes (keyboard shortcuts still available)
- Undo / Redo buttons lets you undo / redo local changes (with 100 possible undo operations)
- The elevated grid point remains selected at screen after mouse button is released
- Elevation is editable to fine tune values
- It's possible to copy the current elevation on other points with a right click (or ctrl + click under macOS)
- When you draw a closed space with the right mouse button pressed (finishing on the point where you started), a dialog box is displayed to confirm whether all points within this space should be elevated (see demo video – 5 MB)
- Performances while elevating points were greatly improved
- The rotation around the vertical axis is done at the closest degree
- The length unit used in Influence radius spinner was fixed.
Hope this will satisfy most requests smile
