Print at Oct 2, 2026, 12:16:50 PM
Posted by Keet at May 23, 2022, 3:03:35 PM
Re: Stainless Steel Texture?
First do what Daniels118 suggested, export your walls with a texture on both sides. This can be any random texture since you can change that afterwards. I usually use different textures for each side so I can relate to the sides in the exported obj and mtl file for renaming the object properties before I import again.
When you apply your stainless texture and it doesn't look alright you can experiment with setting a different scale. If you want to see what that does apply a sky texture to a wall and see what difference it makes when you set a scale of 1000 or larger. It effectively changes the grid size for each texture 'tile'.
By-the-way, the multiple file textures are used in 3D design software and are a kind of layers for the texture (opacity,roughness,etc.). Usually one of the files is the 'normal' texture. Sweethome3D can only handle single file textures.
