Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Add "o" to OBJWriter output » » » » Post: Re: Add "o" to OBJWriter output |
Print at Sep 28, 2026, 1:30:44 PM |
| Posted by Keet at Jun 17, 2022, 9:00:03 PM |
Re: Add "o" to OBJWriter output I did a little test by exporting a single wall. The OBJ file has 6 g groups, as it should, because you want to be able to apply a texture to each "side". A single piece of wall is just like a box. Adding an o object name changes nothing when importing into Blender, the same 6 object parts remain the same. The only way to get a single object into Blender would be to merge all g groupings into a single g group. I haven't tested this but I suspect that you loose the separate textures. From my point of view a single object in Blender is virtually useless, you want things to be as separated as possible because it allows you to manipulate them individually. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 28, 2026, 1:30:44 PM |
