Print at Oct 7, 2026, 1:15:56 AM
Posted by Puybaret at Jun 21, 2022, 2:25:35 PM
Re: 2 storey - floor - wall - floor -wall
The "ghost" of the walls at the ground floor should be visible at the upper level to help you draw walls there. Isn't it the case?
When magnetism is activated, It should help you to draw walls at the same location in the upper floor. You could also copy-paste walls from the lower level to the upper level.
