Print at Sep 28, 2026, 11:07:25 PM
Posted by sjb007 at Jul 5, 2022, 1:54:58 AM
Re: My own home (as is)
It depends on what the purpose of the model is. Is it going to be used as part of getting required permissions or permits? Or is it just for a starting point for figuring out what changes you wish to make?
Not knowing what your planning departments require, I'd say it is likely not enough for your "existing" plans/drawings. It certainly can't produce the necessary drawings for my location.
For re-imagining your home, I'd say it is a good model to start from... with one exception. Your levels make no sense. I have to hide things (the roof) to see either the plan or an overhead aerial view.
Roofs should be on a separate level "above" the "PB-Architectura" level so that I can select "PB-Architectura" and see the ground floor layout easily. By "above" it can keep the same elevation, just above "PB-Architectura" in the level list.
Also consider that most of your time and focus will be on the ground floor layout of your home. Consider putting everything else (garden and boundary walls, the other small building, etc) on another level also at the same elevation. This just makes it easier to focus in on the main building when figuring out your changes by using Ctrl-Shift-H to hide all the other levels.
Last suggestion (I promise) is to mark any load bearing walls, if any. Maybe use a different wall pattern in the plan. That way it is easier to see what cannot be shifted, and must be incorporated into any new design. In particular check if your roof ridge is supported at all by the walls that look like they run directly underneath.
Without knowing what constraints you have, and what you think you could do, I have to say the current design looks very efficient and compact. I'm struggling to see how the current plan could be improved without extending out or up. (I'm assuming you want to keep it a 3-bedroom property.)
