Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Dartboard Cabinet + Dartboard » » » » Post: Dartboard Cabinet + Dartboard |
Print at Oct 4, 2026, 6:06:33 AM |
| Posted by Keet at Jul 23, 2022, 6:01:38 PM |
Dartboard Cabinet + Dartboard A lazy Saturday furniture creation - Sourceforge 3D Model ![]() This detailed dartboard cabinet has opening doors and changeable text on the score board for which a GIMP image file is added. Of course you can also change the png which is delivered with the model before importing. Several parts can be modified or made invisible (markers, pen shelf, right side shelves, score board). The Dartboard itself is a free download from archive3D.net which needed several changes because multiple numbers were out of position or mirrored. The result is a correct dartboard with the darts removed. The dartboard is available as a separate zip download from the same 3D Model page. All modify options: ![]() Be aware that this is NOT a small model but the dimensions are compliant with the official rules if you elevate the Dartboard 150cm. The cabinet needs a 120cm elevation to fit nicely. Distance from the front of the board to the "oche" is 237cm. (The oche is the low barrier against which you place your foot when throwing.) You'll have to draw that yourself The cabinet is 100% created with Sweethome3D, nothing else. This includes the custom created hinges. Those might be interesting to 'steal' for other projects. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 4, 2026, 6:06:33 AM |
