Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Patch submission » » » » Post: Re: Patch submission |
Print at Sep 23, 2026, 4:31:36 PM |
| Posted by nathanjshaffer at Aug 2, 2022, 5:13:01 PM |
Re: Patch submission Patch submitted - ticket #1090 No functionality lost as far as I am aware. I am still working on making the new version save/load and will need to be able to update older saved files to the new version. I also didn't completely replace all of the float arrays in the entire codebase. It was a lot of time going through it all, so i created a conversion function to shortcut as I need to simply get it to build and test. so some of the classes that are completely unrelated to walls still use float[]. At some point I will get around to doing everything. this was more of a proof of concept. I am researching constraint solver algorithms. I found a university dissertation where someone had written a simple 2D solver in java. I contacted her to see if I could get the source code, but she no longer has it unfortunately. The paper is here and has some sample Java classes as well as psuedo-code for the pan algorithm. It will take some doing to get it all figured out, but should make this project far more capable. |
Current timezone is GMT Sep 23, 2026, 4:31:36 PM |
