Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: 3D Render with a Transparent Background » » » » Post: Re: 3D Render with a Transparent Background |
Print at Oct 3, 2026, 1:58:42 AM |
| Posted by Daniels118 at Aug 3, 2022, 5:45:47 PM |
Re: 3D Render with a Transparent Background I think this is not possible without modifying the program. A possible workaround could be to set a ground color that is very different from every other color in the model, such that you can easily cut it away using an image editor such as Photoshop or GIMP. These programs don't require that you cut along the edges manually, they will find them by themselves based on the color choosen and allow to set a tolerance which compensate for the color variations introduced by the shading. They also account for antialiasing of edge pixels, so you should get very good results. |
Current timezone is GMT Oct 3, 2026, 1:58:42 AM |
