Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Export_Too_Small » » » » Post: Re: Export_Too_Small |
Print at Aug 26, 2026, 2:49:31 PM |
| Posted by Puybaret at Aug 5, 2022, 6:51:12 AM |
Re: Export_Too_Small You may have placed some very small objects at the borders of your plan that you should remove (use Edit > Select all menu item and zoom out to find them easily). Or you created different levels, and one these levels is much larger than your home plan (maybe for the garden?). In that case, make the larger level unviewable to get a smaller print. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 26, 2026, 2:49:31 PM |
