Print at Oct 4, 2026, 3:24:51 PM
Posted by hansmex at Aug 5, 2022, 2:52:24 PM
Re: Need Pro-Help!
Maybe this works:
- draw very thin walls in the shape of your shelf, you can also make rounded corners
- set the walls to a height of a few centimetres, corresponding to the thickness of your shelf
- insert a room
- delete the walls, then export and import the room
- this should give you the desired shelf
